Printing mechanical part
My son wants to print a mechanical part for a school project. We used supports but it's very difficult to remove these without damaging the part. Is there another solution to print this properly?
See .STL file in https://we.tl/t-8YAWw1PxME
Thx for your advice!
Publié : 19/11/2024 8:53 pm
RE: Printing mechanical part
you could try this...
coil (2)
it's rotate9 90degrees to reduce the supports.
and the supports overhang threshold is set to 30degrees which may be a bit small if it droops try 40degrees
Publié : 19/11/2024 10:09 pm
