Preheat oozing, and wispy stringing
ChinookCrafts
(@chinookcrafts)
I am uncertain if the two issues are connected, but I figured I would mention them both.
My mk3s+ (preassembled) is printing phenomenally, but I have experiencing two issues from the start. The first is an oozing of filament during PLA preheat, usually around 2" or so (215 degrees). This isn't a problem, but I do have to repeat the preheat step between every job or else it oozes during the 9 point calibration and gunks up the nozzle.
The second issue is very thin cotton candy like wispy stringing between any parts that are separated by a small gap. It's quite excessive and occurs between multiple points on a single print, and between a single job with multiple prints.
It may be worth mentioning that I also get tiny, tiny raised flicks on the top surface of irregular prints whenever the printer is done a layer. It may be a result of the same oozing problem though, as when a job is finished it does continue to ooze another inch or so over the next minute.
Any insight would be welcome!
Publié : 09/06/2022 4:15 am
jsw
 jsw
(@jsw)
RE: Preheat oozing, and wispy stringing
Irregular prints and stringing are often due to damp filament.
The first thing I would do is dry the filament to be sure.
Publié : 09/06/2022 6:02 am
ChinookCrafts
(@chinookcrafts)
It's all factory. Brand new, upwards of ten or so stock rolls over the last 8 months.
Checking again this morning, I do get a tiny blob after the initial prime strip and wipe before it moves onto the skirt, so the oozing does seem to be consistent during the whole print, and is manifesting in the stringing due to the fast movement.
Are there any settings that deal with ooze primarily? Perhaps it's attempting to relieve pressure? Flow rate, retraction? I am still new to this.
Publié : 09/06/2022 3:15 pm
Cadme1ster
(@cadme1ster)
You can adjust the startcode in order to heat to let’s say 170c before 9 point calibration to prevent oozing and afterwards heating to print temperature 215 for pla.
for stringing, oozing, blob and so on… this sounds like overextrusion. Try calibrating flow.…. And dry the filament.
Ce message a été modifié il y a 4 years par Cadme1ster
Publié : 09/06/2022 7:02 pm
ChinookCrafts
(@chinookcrafts)
I will look into remedies for over-extrusion, but changing the pre-heat start code wouldn't accomplish much. The oozing occurs during the pre-heat process no matter when it occurs. At least if I use the preheat function before the job I can remove the oozing in a controlled way, rather than trying to snag the debris before it does the priming and skirt.
Are there any recommended guides for adjusting Flow and/or Overextrusion?
Posted by: @mpothmann
Publié : 09/06/2022 7:19 pm
hawai
(@hawai)
Do not easily dismiss the idea of tinkering with the start code. @bobstro, and I'm sure a few others wrote a modified startup routine that works quite well and addresses a few potential issues. I didn't bother to look for the original source atm but here is what I have in my modified startup code (thanks again @bobstro!):
; Last updated 20191117
M300 S40 P10 ; chirp
M862.3 P "[printer_model]" ; printer model check
M862.1 P[nozzle_diameter] ; nozzle diameter check
M115 U3.7.2 ; tell printer latest fw version
M117 Initializing; Set coordinate modes
M83 ; extruder relative mode
; Reset speed and extrusion rates
M200 D0 ; disable volumetric e
M220 S100 ; reset speed
M221 S{if layer_height >= 0.32}90{else}100{endif} ; compensate for thick layer heights
; Set initial warmup temps
M117 Nozzle preheat
M104 S160 ; set extruder no-ooze temp
M140 S{max(first_layer_bed_temperature[0],75)} ; set bed PINDA warmup temp
; Nozzle warmup before home to avoid driving hardened ooze into PEI surface
M109 S160 ; wait for extruder no-ooze warmup temp before mesh bed leveling, cool hot PINDA
M300 S40 P10 ; chirp; Home
M117 HomingG28 W ; home all without mesh bed level
; Present bed for final cleaning <- I removed the g-code for that one, originally it did a full outward y-axis move, chirped and waited for a few seconds before continuing
G0 Z3; Raise nozzle before move
G0 X125 Y180 F10200; Move nozzle to PINDA warming position
G0 Z0.15 F10200; Lower nozzle to PINDA warming position
; Wait for PINDA warmup
M117 PINDA warmup
M860 S35 ; wait for PINDA temp to stabilize
M140 S[first_layer_bed_temperature] ; set target bed temp
; Mesh bed leveling
M117 Mesh bed leveling
G80 ; mesh bed leveling
M117 Saving results
G81 ; save mesh leveling results
; Final warmup routine
M117 Final warmup
G0 Z5; Raise nozzle to avoid denting bed while nozzle heats
M140 S[first_layer_bed_temperature] ; set bed final temp
M104 S[first_layer_temperature] ; set extruder final temp
M109 S[first_layer_temperature] ; wait for extruder final temp
M190 S[first_layer_bed_temperature] ; wait for bed final temp
; Prime line routine
M117 Printing prime line
G0 Z0.15 ; Restore nozzle position - (thanks tim.m30)
M900 K0; Disable Linear Advance for prime line
G92 E0.0 ; reset extrusion distance
G1 Y-3.0 F1000.0 ; go outside print area
G1 E2 F1000 ; de-retract and push ooze
G1 X20.0 E6 F1000.0 ; fat 20mm intro line @ 0.30
G1 X60.0 E3.2 F1000.0 ; thin +40mm intro line @ 0.08
G1 X100.0 E6 F1000.0 ; fat +40mm intro line @ 0.15
G1 E-0.8 F3000; retract to avoid stringing
G1 X99.5 E0 F1000.0 ; -0.5mm wipe action to avoid string
G1 X110.0 E0 F1000.0 ; +10mm intro line @ 0.00
G1 E0.6 F1500; de-retract
; Final print adjustments
M117 Preparing to print
M117 Print in progress
M221 S{if layer_height<0.075}100{else}95{endif}
By doing the mesh bed levelling at a non ooze temp this avoids spreading blobs and droplets over the bed. Works really well and I hadn't any mesh bed levelling blobs since then. I don't know if the SuperPINDA is as sensitive to temperature changes as the PINDA on the Mk3S but it definitely won't hurt to have the build plate heated to a uniform temp before the mesh bed levelling.
Regarding the stringing I'm with @jsw. Depending on the brand and within some brands even on the production batch there are some moderately poor quality filaments out there. If you have access to a dehydrator it won't hurt to give it a go. There is also the option of printing a temp tower to find the right printing temp for your specific filament. Sometimes a few degrees make a significant difference. Also look at the extrusion multiplier setting, reducing it by a few percent might also help as well as the retraction settings. There are unfortunately many knobs you can and might need to turn to get it right.
It seems that so far I have been an extremely lucky bastard and most of the prints go well enough for my expectations or needs so that I hadn't to go through all this.
hat
Hansjoerg
Publié : 09/06/2022 10:16 pm
ChinookCrafts
(@chinookcrafts)
So I have done many, many tests, and the main culprit seems to be a tiny bit of oozing at the end of every extrusion. When the nozzle does the z-lift, the filament strings and is dragged in the direction of the next extrusion.
I print a lot of fantasy gaming terrain, so this is VERY problematic for things like cobblestone streets, where every single stone has a 'nick' on the top error. I am not getting smooth tops at all. I can see now these are all symptoms of the same problem.
Is there anything I am overlooking?
I've tried the retractions settings, and dropping the extrusion multiplier in case I am overextruding. Disabling wipe, and reducing the z-lift as much as I dare.
Publié : 15/06/2022 5:33 am
try dropping extrusion temperature a little and try setting retraction for PLA to 0.4mm
Publié : 15/06/2022 7:23 am
