PETG Issue
SnowEagle
(@snoweagle)
PETG Issue
What is causing this ridge? See Photo!
USING:
PETG Carmine Red - Filament
Pretty PETG v3 - Profile
PrusaSlicer v2.1.1
Publié : 03/03/2020 1:43 pm
GKMAKEIT
(@gkmakeit)
RE: PETG Issue
You talking about the upper, lower or both "ridges"? The lower one is where the seem for those layers started and stopped.
Ce message a été modifié il y a 6 years par GKMAKEIT
Publié : 03/03/2020 6:02 pm
SnowEagle
(@snoweagle)
RE: PETG Issue
@gkmakeit
I understand what caused it, I'm interested in learning how to stop it from happening.
Publié : 03/03/2020 6:12 pm
RE: PETG Issue
Posted by: @jsgott
Unless you're printing in case mode, you cannot eliminate the z-seam in current consumer-grade FFF 3d printers. You can hide it in corners, but on cylindrical shapes, it has to go somewhere. You can randomize the location, but that tends to create unsightly zits. Locating it on a hidden side is usually the best option.
You can mitigate the effect with filament extrusion multiplier and linear advance tuning. Your choice of filament affects visibility.  Here's an example:
Publié : 03/03/2020 7:21 pm
GKMAKEIT
(@gkmakeit)
RE: PETG Issue
Posted by: @jsgott
USING:
PrusaSlicer v2.1.1
I was just answering the question as I saw it “What is causing this ridge?”, not how do you fix it. 😀
Publié : 03/03/2020 7:30 pm
SnowEagle
(@snoweagle)
RE: PETG Issue
@gkmakeit
Sorry if there was any confusion.
Publié : 03/03/2020 7:54 pm
SnowEagle
(@snoweagle)
RE: PETG Issue
@bobstro
Is there a way to know where it is going to be and therefore be able to rotate the image to have it in a less conspicuous place?
Publié : 03/03/2020 7:58 pm
RE: PETG Issue
Posted by: @jsgott
@bobstro
Set it to rear and rotate the part on the bed. At least until PrusaSlicer gives us more control.
Publié : 03/03/2020 9:22 pm
SnowEagle
(@snoweagle)
RE: PETG Issue
@bobstro
"Set it to the rear"
I'm not sure I understand, How can I find out where this seam is going to start printing on the part.
Publié : 03/03/2020 9:56 pm
RE: PETG Issue
One of the seam placement options is rear. This puts the seam on the back of the model with respect to the bed. So you can rotate the model so that the seam gets placed in a line and you control where the line is as you control the model placement.
Publié : 03/03/2020 9:59 pm
SnowEagle
(@snoweagle)
RE: PETG Issue
@neophyl
Thanks!!! I see the setting it was on Aligned.
Publié : 03/03/2020 10:09 pm
