Overhang varies in quality
Hello, im trying to print this round objekt. i use ASA.
i use 100% cooling on 0% overlap and 80% cooling on 50% overlap.
the objekt in both pictures is the same from different angels.
one one edge the print is fine(first pictue) but on 70 % of the curve it has this strange curling (second picture).
i have no idea what it could be since it worked in the past and gets worse with every objekt.
you can also see that the overhang right in the picture (witch is printed first is almost perfekt).
thanks in advance.
Opublikowany : 23/06/2024 9:13 am
If it has worked in the past and is getting worse then the first place to look is the fan. Is it obstructed? Does it need cleaning? Does it need lubrication?
Opublikowany : 23/06/2024 10:14 pm
