Issue printing simple 3 part design
Chris
(@chris-38)
Hey guys,
I'm trying to print the following simple cutter I designed consisting of 3 individual parts.
The screenshot was taken while trying to slice using sequential printing. I'd like to use sequential printing because it failed twice printing it "regularly"
I attached the project file: cutter_sequential
Could someone explain to me why it is not possible to print the 3 parts sequentially ? - I feel like it should be possible with the MK3S+ I trying to print it on and I followed the sequential printing guide.
Would be super happy about any help/input !
Thanks guys
Chris
Respondido : 27/03/2023 7:12 pm
RE: Issue printing simple 3 part design
I can't claim to be a real expert on sequential printing but whenever I used it I found that the Height setting for Extruder clearance seems to be the opposite of what the knowledgebase page set (or I totally misunderstand the explanation). At least in my hands it's not the distance of nozzle and x-axis rod but the height of the tallest part. So in this case, if you set Height to 135mm, it will slice fine. I usually set it to quite a bit higher than the tallest object.
On a different note, I'm not sure why this print would fail in regular print mode. The thin, tall object may require a brim to stay in place, though.
Respondido : 27/03/2023 11:09 pm
1 les gusta
