Inconsistent first layer
Hello,
Ive assembled my mk3s kit and i really struggle with first layer. It seems that a part of print is OK and a part of print is not ok. Ive tried so many things now and nothing helps. On print 50x30 mm i get some different patterns and i dont know how to get rid of the.. it was way worse with the silver PLA filament which came with the kit. Today i swapped to white PLA filament and it has really great bottom right corner and aome spots on the print, but also have some patterns on it. Printing at 205/60 and 215/60 for silver PLA. Ive tried changing flow, em, first layer mm, also fill angle (no picture attached) but nothin helped.
I think my live z is almost lowest possible. But what bothers me its not consistent...
Check picture attached.
RE: Inconsistent first layer
You're very close. Be sure you've enable 7x7 mesh bed leveling in the setup menu. It gives more granular leveling results.
@bobstro
Hi, thanks for the reply. I'll try once again with live Z,
but this opens new questions. If Z would be correct/incorrect,
wouldnt whole printed first layer be nice or ugly? I cant connect how
live Z is connected with just few ugly spots on first layer?
7x7 mesh is enabled btw
Ok, why is quoting so wierd on this forums?
