Incomplete layers
Suddenly my MK3S started printing incomplete layers. The errors occur in different places each time. Does anyone know what would cause this?
Best Answer by Dan Rogers:
Have you checked for a clog? Try a cold pull - avoid using the needle. If the feed tension screw is too loose, any binding in the spool holder may cause that kind of symptom. Under-extruding and then coming back - is often a binding issue.
Hmm
That is odd. Can you post the filament type and manufacturer? Also, it might help if you upload a 3MF filled zipped.
Clog? Feed gets wonky? Loose tension screw?l
Fixed
The cold pull and tightening the tension screw fixed the issue. Thanks Dan!
