Incomplete layers
MercuryMage11
(@mercurymage11)
Incomplete layers
Suddenly my MK3S started printing incomplete layers.  The errors occur in different places each time.  Does anyone know what would cause this?
Best Answer by Dan Rogers:
Have you checked for a clog?  Try a cold pull - avoid using the needle.  If the feed tension screw is too loose, any binding in the spool holder may cause that kind of symptom.  Under-extruding and then coming back - is often a binding issue.
Opublikowany : 06/10/2021 4:57 pm
Hmm
That is odd.  Can you post the filament type and manufacturer?  Also, it might help if you upload a 3MF filled zipped.
Opublikowany : 06/10/2021 7:06 pm
Dan Rogers
(@dan-rogers)
Clog? Feed gets wonky? Loose tension screw?l
Opublikowany : 07/10/2021 4:30 am
MercuryMage11
(@mercurymage11)
Fixed
The cold pull and tightening the tension screw fixed the issue.  Thanks Dan!
Opublikowany : 11/10/2021 3:16 pm
1 ludzie polubili
