How to print Fiberology FIBERFLEX 40D
Hi!
I am having great difficulty in printing this material Fiberology FIBERFLEX 40D on my MK3s.
It is supposed to be one of the "easiest" semi-flexible filaments to print according to several reviews on youtube:
What I have tried so far: I started by choosing the material profile for the "Semiflex or Flexfill 98A" in Prusa Slicer. Then I modified the settings per the manufacturers recommended settings:
https://fiberlogy.com/en/fiberlogy-filaments/filament-fiberflex-40d/
Max Volumetric Speed was set to 1.35 mm^3/s, which should keep the speed low and smooth?
The currently obtained results are not remotely close to being good. Here is a simple round gasket with 3-vertical shells and something like 7 horizontal shells:
What should I try to improve this?
Best regards, Fredrik
RE: How to print Fiberology FIBERFLEX 40D
I got good results with the setting on their website. If I want to improve them, I slwo the print down.
If your willing to post your Zipped up .STL file I'd be willing to give it a go with Ninjaflex it's durometer 85A (even softer then 40D) and I've had great success printing it on my stock i3 MK3.
The Filament Whisperer
Hope this helps someone else. My first few prints with this were awful, lots of stringing and very poor bed adhesion. I tried a few different settings that folk recommended but the print would not stick to the bed (satin, powder coated). I then tried the regular bed and it stuck like absolute glue and I couldn't get it off. I tried magigoo on the satin sheet but the print still kept coming off. I tried magigoo on the regular bed and that worked quite well in that it appeared to adhere and I could get it off at the end. Finally I tried *raising* the bed temperature of the satin sheet to 70C for the first layer - this worked really well! Adhered well but came off at the end. My final print was night and day with the one I started with. Here were the other main settings I used (I got most of these from https://www.thingiverse.com/thing:4352738/files) main thing is hotter extruder, especially for first layer:
