How to get supports under bridging areas?
tenkun2020
(@tenkun2020)
Haven't been able to get supports under bridging areas. I have tried adding a raft and skirt to the print but still cant get it some places.
Here is some screen shots of  my issue and my printer settings. I have had the same problem with some other prints as well. I think the problem lays in the the proximity to the print plate/raft and the software's support placement resolution. Does any one know how to fix or get around this problem.
Postato : 19/10/2020 3:55 pm
jsw
 jsw
(@jsw)
RE: How to get supports under bridging areas?
Uncheck that 'don't support bridges' box that is, for some reason, checked by default.
Postato : 19/10/2020 4:58 pm
It would be useful to know why you are wanting supports under a bridge? What do you want or expect they will do?
Postato : 19/10/2020 7:43 pm
tenkun2020
(@tenkun2020)
@jsw
Thank you for your reply!
I tried doing as you suggested, unfortunately I got the same result as first photo.
Postato : 19/10/2020 10:51 pm
tenkun2020
(@tenkun2020)
@tim-m30
Thank you For your reply and request of more information.
This is more or less an example of what happens without the the supports as demonstrated from a bridging test that I found online.
(all3dp.com/wp-content/uploads/2017/09/27002752/3D_Print_Problems_Bridging-772x434.jpg)
In this model that I threw together on tinker CAD. The red boxes represent a single print layer, while the orange pattern represents where the support is going. this is a side aspect of my problem for helping explain.
the yellow circles on the the dark blue lines are where I need the support at so that the areas with orange squiggles have something to connect to other than open air.
Postato : 19/10/2020 11:17 pm
Can we have a sample STL, zipped and attached as a file please?
Postato : 20/10/2020 1:23 am
jsw
 jsw
(@jsw)
Yes, I would like to see that too.  By unchecking the box PS has always generated the expected supports for me.
Postato : 20/10/2020 1:32 am
That first image shows a normal bridge on a printer that doesn't do so well with bridges. That'd be a matter of fine tuning the print profile to get it to work rather well on a Prusa Mk3 - though even the defaults should print it acceptably.
That second model has bridging perimeters upon which bridges are built ... and is a fair test of a slicer.  Probably a few things in the real world that we'd build will have that specific extreme, but worth figuring it out. If you post up the model as Joan suggested, I'd be interested in playing with it.
Questo post è stato modificato 6 years fa da --
Postato : 20/10/2020 1:56 am
Meanwhile, back at the ranch ... if anyone can explain the second bridge layer having a 5 degree infill angle; I'm all ears.
SupportExtreme
Postato : 20/10/2020 2:17 am
1 persone hanno apprezzato
How I'd do my first attempt ... still can't explain the 5 degree bridging. Might have to post a bug report on this.
SupportExtreme
Postato : 20/10/2020 2:29 am
tenkun2020
(@tenkun2020)
this is the face that I have my model orientation set on
audio scoop v1
Postato : 20/10/2020 3:08 am
Made the part smaller - no reason to waste so much plastic - and tried using the 2.3.0 painted supports. Supports easier to remove, no apparent difference in surface quality.
SupportExtreme-small
Postato : 20/10/2020 6:39 am
Final thought is having a perimeter corner that is also bridging is a pita. Very difficult to get supports under them and maintain a removable contact area that actually supports the corner. You can see the small wedging taking place on the bridged layer in both prints.  If you look close, you can see the support structure left a pattern on the smaller print. To optimize the quality, I'd build supports into the part rather than let the slicer decide: just not enough control in the slicer to deal with all of the issues in that part.
Postato : 20/10/2020 8:56 am
Did a quick manually made support test - not a lot better surface than what Slicer provides. And the corners are a mess to deal with.  Slicer needs a way to limit the size of the supports being generated so they aren't 3x the size actually needed. I'll play with enforcers next, see if I can get the sizes down.
Postato : 20/10/2020 4:31 pm
Pretty sure I've printed stuff with these support issues before. I must have just taken the defaults and lived with the results. lol
After a last ditch effort to get a better print, it seems my knowledge base has failed me. The automatic supports do about as good as it gets. I can improve the exterior bridging perimeters a bit, the long bridges a bit, but only at the cost of a poor hole perimeter & infill join.  Seems the support different needs require non-compatible techniques to get the best result for each, and the slicer doesn't allow for support zones - as far as I know.
I'm open to other ideas if anyone has something to offer.
Postato : 20/10/2020 6:19 pm
