How I print Small things ?!
Good morning guys
I want to print small things. Like the photo or a thin axis. When I print so,etching like that there is a big mess to my print. It prints And the filament is like a ball of yarn.
some advice?! I use to put the big surface in the bed. I also try to increase the bed temperature.only the first layer is on the bed the other is moving with the nozzle. I use pla.
thnx
RE: How I print Small things ?!
Οne more problem. In sign with letters it creates some dots/point for some reason.
any ideas?!
First issue sounds like first layer is not set correctly, follow this method then retry, I gather you have followed all setup procedures in tha manual?
Not sure about the second, some pictures would help please.
Tank you very much!
If larger objects print OK, and first layer is OK use a brim.
Tank you very much!
@clarmrrsn
Thnx a lot. How much width mm is good for brim?!
I use 3-5mm for a brim. That part should print fine without a brim. Be sure your PEI print surface is well cleaned and that your Live-Z is adjusted properly. Are you using a smooth or textured print surface? What filament are you using?
A very thanx. It works thanx!!!!
one more short question for extrusion. I got dots in a top layer. As I read there is overextrusion.
I go to prusa slic3r then filament settings and I change where it says extrusion multiplier to 0,8 just to try. But when I print I go to print menu then tune then flow and it says 100.is the same or not?!that is the difference?!how can I save the flow value from the printer menu.
thanx
@cycleman
Extrusion multiplier is explained here
https://help.prusa3d.com/en/article/extrusion-multiplier-calibration_2257
If you are still having an issue after this please post a photo and someone will assist.
Tank you very much!
