Help with my Prints
Strona 2 / 2
RE: Help with my Prints
@pablo-f-2
Have you tried the
'Life Adjust 'Z' My Way'
process
and are you using 7x7 mesh bed levelling, available on the LCD Display
it tests 49 points on the build plate instead of the normal 9 points...
Opublikowany : 24/11/2020 7:10 pm
Pablo-F
(@pablo-f)
@joantabb
 Yes i am Zaungast the Life Adjust 'Z' My Way'
but 7x7 49 points, no not yet.
thank you Joan 😊
Opublikowany : 24/11/2020 10:41 pm
Best wishes!
Joan
Opublikowany : 25/11/2020 2:03 am
Pablo-F
(@pablo-f)
I think with soap cleaning and 7x7 mesh bed levelling i have a very good result of first layer.
Thank you all. 🙂
Opublikowany : 25/11/2020 11:05 am
@pablo-f-2
excellent news...
however If you find the bottom layer of supports is now difficult to remove completely, you could consider adding a raft to tie the supports together and make them easier to get off the build plate...
Opublikowany : 25/11/2020 2:38 pm
1 ludzie polubili
Pablo-F
(@pablo-f)
@joantabb
i am since one week into 3D printing, and i have no idea what a raft is or wehere i can make one. 🙂
I have to look that up somewhere.
I am using the auto support "everywhere"
thank you very much Joan for your help
Opublikowany : 25/11/2020 2:48 pm
@pablo-f-2
A raft is in the setting for PrusaSlicer.
Here is a good rundown of what rafts are:
https://www.simplify3d.com/support/articles/rafts-skirts-and-brims/
Opublikowany : 25/11/2020 2:58 pm
1 ludzie polubili
Fine first-layer supports as shown in the 1st post should be no problem on the smooth PEI sheet washed only with Dawn dish soap and no alcohol. By all means, try isopropyl alcohol. Don't just use a dampened cloth. Pour on a good squirt and give it a wipe. But if you still have adhesion problems, nothing beats a wash under the sink with plain dish soap.
Opublikowany : 25/11/2020 3:24 pm
Pablo-F
(@pablo-f)
Here you can see the finish print
Opublikowany : 26/11/2020 12:30 pm
@pablo-f-2
Pretty neat print.  Need to tighten up the setting and it might need different support settings.
Opublikowany : 26/11/2020 12:38 pm
I Guess your adhesion is sorted for the moment
Opublikowany : 26/11/2020 12:53 pm
1 ludzie polubili
Pablo-F
(@pablo-f)
Posted by: @cwbullet
@pablo-f-2
yes i think so too, need to find out more about support settings, maybe the new slicer will help 🙂
Opublikowany : 26/11/2020 2:37 pm
Pablo-F
(@pablo-f)
Posted by: @joantabb
thank you Joan, until next time 😉 😆
Opublikowany : 26/11/2020 2:38 pm
Strona 2 / 2
