Gluestick and coated sheet possible
Facebraker
(@facebraker)
Hello, i want to print PETG, is it possible to use Gluestick with the coated sheets as separation medium ?
Thank you
Veröffentlicht : 01/10/2019 2:29 pm
Lichtjaeger
(@lichtjaeger)
RE: Gluestick and coated sheet possible
Why not?
But why do you need it at all? After the bed was cold each of my PETG prints was totally loose. I didn't need any build plate preparation.
Veröffentlicht : 01/10/2019 2:43 pm
Which sheet do you have?
The textured sheet doesn't need anything for PETG.
The smooth sheet needs something to reduce PETG's grip. For PETG printed below 240C, a spray of Windex or just a few wipes of your fingers on a clean bed is sufficient. If using higher temps, glue stick may be necessary.
Veröffentlicht : 01/10/2019 3:29 pm
Facebraker
(@facebraker)
@bobstro
i had the textures sheet.
Veröffentlicht : 01/10/2019 3:37 pm
Another random factor to consider: some PETG sticks like superglue; some PETG wants a clean sheet (smooth PEI).  So use Windex and try a very small part. If it sticks well enough you are good to go; if it doesn't stick, it's the PETG that favors clean; if it sticks better than expected, use glustik for safety.
Veröffentlicht : 01/10/2019 4:22 pm
Mitglied
Posted by: @tim-m30
Isn’t that the truth!  No two PETGs are the same.
Veröffentlicht : 01/10/2019 5:56 pm
Mike Daneman
(@mike-daneman)
Very true.  The 2 PETGs I've tried to print so far (Prusament Orange, and Overture Black) both wanted dishsoap washed sheet and Overture wanted an IPA wipe in addition.  Both popped-off just fine when the plate was cool.  I've now started doing a soap wash AND an IPA wipe for my PETG runs.  So I have yet to print a "sticks like superglue" PETG, but clearly some people have that experience.
Veröffentlicht : 01/10/2019 8:12 pm
Posted by: @mdaneman
[...]  So I have yet to print a "sticks like superglue" PETG, but clearly some people have that experience.
If you want a challenge, try 3DXTech Matte PETG at 270C! That was the downfall of my 1st PEI sheet.
Veröffentlicht : 01/10/2019 9:47 pm
Mitglied
I have tried at least 20 brands.  I am contemplating doing reviews if there is an interest.
Veröffentlicht : 01/10/2019 10:24 pm
Mitglied
Posted by: @bobstro
How did you finally get it to print?
Veröffentlicht : 01/10/2019 10:26 pm
Posted by: @charles-h13
Gluestick worked for the 2nd try, but I found MagiGoo a less messy alternative. Here's the same print on the same (damaged) PEI surface after printing with MagiGoo:
Veröffentlicht : 02/10/2019 1:09 am
Mitglied
Magigoo is awesome.
Veröffentlicht : 02/10/2019 1:31 am
Sembazuru
(@sembazuru)
Magigoo is awesome.
It's almost like it is magic goo... Oh... Wait... lol
See my (limited) designs on:
Veröffentlicht : 02/10/2019 1:48 am
Posted by: @sembazuru
Until you get sloppy and try to apply it to a hot bed. Then it's just an expensive scrubber.
Veröffentlicht : 02/10/2019 2:01 am
Mitglied
@bobstro
True.  I have not used it on my PC sheet.  I have not seent the need.
Veröffentlicht : 02/10/2019 9:48 am
