Gap in perimeter
LuFab3D
(@lufab3d)
Gap in perimeter
I struggle trying to print a very easy part. This is basically a box with only one perimeter, and a wall splitting the box into two cases.
I use 0.6mm nozzle, and the model walls are all 0.6mm wide.
On all 4 corners of this internal wall, the perimeters do not merge, and there is a gap (see below).
What I tried to do :
  • Update Slic3r to 2.6.1 and printer firmware to 3.13.2 (MMU to 3.0.1) - I don't use MMU2S for this print (set to MK3S+ / MMU2S Single)
  • Change the seam position (from "aligned" to "random")
  • Change the width of the internal wall (from 0.6 to 1.2mm). Anyway, the wall prints fine (1 or 2 perimeters), but the external perimeters do not join.
  • Import two boxes (without internal wall), and merge them side to side with Prusa Slic3r.
When I look at the gcode output through Prusa Slic3r, I don't see anything strange.
Would you have any clue/strategy to print such a piece?
Thanks a lot!
(I tried to attach the .m3f and .stl files on this topic but it does not work (format not supported).)
Ce sujet a été modifié il y a 3 years par LuFab3D
Publié : 04/11/2023 6:08 pm
3Delight
(@3delight)
Modérateur Moderator
RE: Gap in perimeter
To attach the .3mf file you need to zip it...
Publié : 04/11/2023 6:15 pm
LuFab3D
(@lufab3d)
Thanks.
Here it is: .3mf files
(2 files : one with a single part, and the other one with the two merged boxes, none of them work fine).
Publié : 04/11/2023 6:20 pm
