Fine details are not printed correctly
BFreakout
(@bfreakout)
Hello Community,
i have a Prusa i3 MK3s + and i am a beginner.
I would like to print the following part:
With the first layer, the printer always has a problem precisely at the top where detailed small curves are involved.
(Admittedly, it looks a little better in the picture. The rest of the prints were much worse, it had almost no shape (the tip) )
I tried the following:
- The speed of the first layer is set to 5 mm / s
- Bed completely cleaned
- Glue stick used
The speed has improved a bit, but as you can see in the photos, it is not ideal.
What do you do with such detailed prints that they succeed?
Postato : 29/12/2020 1:38 pm
RE: Fine details are not printed correctly
Welcome, bfreakout
the left hand end looks a bit melty...    could you try a lower temperature?
does the first layer look OK in slicer?
Can you re slice it with a 0.3mm first layer?
Postato : 29/12/2020 6:30 pm
awsimac
(@awsimac)
it looks like its having issues adhering to the bed, what material is it? I would recommend increasing 1st layer extrusion and bed temp by 5 degrees if you have the headroom. Also make sure z offset is not too close or far.
Postato : 01/01/2021 10:27 pm
