Filament not advancing
So I have a MK3S+ built from kit. I was able to print a few small items, but I'm having issues now. I removed the filament at one point to move the printer, and I've refed it, but it doesn't seem to be advancing through the extruder. I can see the gears turning through the viewer on the side, but I've put a small mark with a permanent marker on the filament just above the feed point on top, and the filament doesn't seem to be getting pulled into the extruder assembly. I tried applying some downward force to see if it just wasn't fed all the way, no help. I tried removing the filament, cutting a new sharp edge on it, and refeeding; no help. Wondering if there's any other common fixes I can try... preferably without having to take the extruder assembly apart though I realize that's a possibility.
RE: Filament not advancing
Sounds like ptfe tube needs replacing infact I'm pretty certain
Open the idler and watch as you feed in the filament manually.
How far does it get? Is everything lined up? Is there a fragment or blob blocking the top of the PTFE tube?
I turned off the autoload, unloaded, recut, loaded again, and it seems to be working now. Looks like the autoload may have been the culprit, but the end was blunted when I pulled it out. Maybe I cut it at too sharp of an angle?
