Dislodged print despite good first layer
In running a print, we achieve a good first layer adhesion, with an 8mm brim around the full base of the print, with good first layer adhesion achieved, the print then dislodged itself and crashed, I'm guessing because the bed moved too quickly for its height, print was with nylon filament. Is there a setting which could potentially be used to prevent this from happening in the future? or is there a different reason why this print may have failed? This failure occurred 2 days into a print as well so was hoping to get some assistance on a potential fix before retrying.
Opublikowany : 02/05/2023 7:32 am
