Curling Issue
Hi guys Iam having Lots of problem with curling small parts I allready Failed 6x times to print this file
my issue is with body part where there are small parts and they always end up curling and then the printre hiting those part out of print bed.
I really dont know what to do
So far I try This:
Chanze Zlive
Nylock mod done
tried blow cold air from outside onto printer 😀
also tried slow print speed 50%
Iam using yellow prusament
RE: Curling Issue
What type of filament and what setting are you using in slicer?
RE: Curling Issue
Stock setting
Prusament pla yellow
.0.20 quality
Print in place mechanisms always require a near perfect first layer, you need a very clean bed and a precise first layer Z calibration.
Chanze Zlive
Please show us a first layer Z calbration print *on the print sheet*
Nylock mod done
This is very popular, I don't know why, it doesn't actually do anything useful as far as I can tell.
Cold drafts *cause* uneven cooling. Protect the printer from drafts.
I would expect this to help a little ...
Concentrate on your first layer and the rest should be OK.
RE: Curling Issue
I Done nylock because few ppl had problem with curling And that help. But not for me :/
Another fail i tried lower pla temp. And same result. Strange thing IS if i print that small part alone IT Will printed pefectly. But when i print all parts together then IT start failing
RE: Curling Issue
Well, my drink of choice is Tequila, however even when I'm drinking I know that, Curling is generally caused by improper cooling, certain models need to have the filament temperatures, bed temperatures, and cooling balanced to prevent this, I'm going to post a link to a thread that may offer some helpful advice even though it's not specific to your troubles, it offers reasonable advice about cooling troubles.
I think this might help you, if you have questions, just ask.
Good luck,
Swiss_Cheese
The Filament Whisperer
I have seen many claims but none that I believe.
Your first layer looks OK.
Two thoughts:
I've never seen a print-sheet wear in quite that manner, try another print-sheet.
@swiss_cheese is right, your cooling is somehow imbalanced. Read the thread he linked. Begin by protecting your machine from drafts and reduce the fan speed.
RE: Curling Issue
I saw folks claim the nylock mod are the cure for everything. I have never done that mod and continue to have the bed as is and it works perfectly 99% of the time.
RE: Curling Issue
Amen to that!
RE: Curling Issue
My experience is that doing small pieces one at a time always works better than trying to do several at a time.
RE: Curling Issue
I prefer print all pieces one by one but this stl IS print in place so no chance :/
Please show us the underside of a/some failed print(s)
