Corner Bubbling and Rough
Hello,
I've had this Prusa MK3S+ for a few weeks now and mostly doing good prints with it.
When I have something that has a large flat surface I sometimes end up with bubbly and rough edges like this.Any ideas what could be wrong or hints as to what I need to try to start adjusting?
This is using PLA, 60C Bed, 215C Nozzle for first layer.
Other layers 60C Bed, 210 Nozzle.Fan On,PLA, Overture Brand.
This specific print was a 0.20mm with 10% infillIf I missed an important number that defines this problem, please let me know, still a newbie here.
RE: Corner Bubbling and Rough
Are we looking at the bottom or top? Could be Live Z too low if it's bottom. If it's top, I'd raise the infill level to 15 or 20%. 10% is in my experience too low for large flat surfaces to avoid pillowing.
Thank you fuchsr, this is the top, so on the print bed this was the very last layer.
I had the infill set to 10% for this, so you may be exactly right. Ill raise it up and try the print again. Thank you!!
@stokes776 , was this the fix to your issue?
