Adhesion issues on 3rd layer
WeaselGX
(@weaselgx)
I am having issues with adhesion for select parts of a print starting at the 3rd layer. The base layer and the 2nd layer all look good but on layer 3, a few strands seem to be lifted and not adhering to the 2nd layer (see photo). This is my first large print and I haven't had issues like this with the smaller pieces I've done. I've started this print twice now and both are failing here.
Is this an issue with the default speed? Should I slow down the print?
Thanks!
Opublikowany : 23/03/2022 8:02 pm
HermannSW
(@hermannsw)
RE: Adhesion issues on 3rd layer
If you place your part on different position of heatbed with PrusaSlicer, does it show the issues as well? And if so, at same or different locations?
Opublikowany : 23/03/2022 8:19 pm
WeaselGX
(@weaselgx)
It’s not the same location … the issue just starts happening on layer 3. On my first print, it was at the other corner where a few strands are lifted and that cause the subsequent pass to pick those up and cause the next layer to not go down properly.
I have everything at default settings; didn’t mess with anything. Printing at .15 layer height using quality setting.
Opublikowany : 23/03/2022 8:24 pm
