XZY Calibration Failure issues
velosports
(@velosports)
Hello!  I just finished assembly of the MK3s and have been attempting the calibration wizard, with no success.
1) During the XYZ calibration step, I repeatedly get 'XYZ calibration failed, refer to manual' error message.
2) I have made sure the PINDA sensor is set 1-2 mm higher than the nozzle.
3) The X and Y belt tension is set to 236 (X) and 274 (Y)
4) The right X axis motor continues to raise the right side of the X axis after the left X axis motor stops, so the X axis is not level.
5) The extruder assembly seems to be traveling too far left and right, missing the calibration points.
HELP!!!  Any insight / recommendations are greatly appreciated.
Thanks!
Respondido : 27/09/2020 9:37 pm
Miembro
RE: XZY Calibration Failure issues
Check your grub screws.
  1. The X and Y motors have toothed pulleys which should be fastened using two grub screws, each.
  2. One grub screw should be facing the center of the Flat edge of the motor shaft and the other should be fastened against the curved side of the motor shaft.
  3. The Grub screws should NOT be tightened using the rounded end of an Allen wrench, because that is likely to split the hex cup on the grub screw.
  4. You should use the other end of the grub screw with the parallel sides and flat end.  If the screws are missing, have a look at the magnets on the underside of the heatbed.  If that fails, have a look in the spares bag.
Respondido : 29/09/2020 12:44 pm
