X-Axis Length Error After Nozzle Change
Hjennerway
(@hjennerway)
I've had my MK3S+ around a month, printed tonnes of stuff. I changed the nozzle today and readjusted the PINDA sensor so went to run through the setup wizard again and got an X-Axis length error. I've changed the nozzle before and never had this issue.
I've greased the X-Axis rods and tried adjusting the motor by loosening the screws. Not sure what to try next. If I used Settings-Adjust X-Axis, I can move the X-Axis from 0.0 to +255 without issue (it moves right to the end). It seems perhaps slightly tighter on the right hand side but not so much that it doesn't move.
Video of the calibration: IMG_3232
This topic was modified 4 years ago 2 times by Hjennerway
Posted : 21/03/2022 3:14 pm
