x axis fails the self test
Dreadzly
(@dreadzly)
I have been printing with my i3 mk3s for 6 months now with out many problems.  On Saturday night my printer all of a sudden screwed up the x axis for some reason I was getting a clicking noise when is would move along the x axis and now it wont pass the self test when it gets to the x axis.  It puts the whole assembly about 10 cm from the right side and then when I go to settings and move axis the x axis will only move 10 steps to the left then it stops at 0 and wont go left any further.
Napsal : 21/01/2020 12:36 am
rmm200
(@rmm200)
RE: x axis fails the self test
Power off your printer and move the extruder by hand, left and right.
It should move smoothly to each end. If it does not - you have to figure out the reason and fix it.
Any binding will make the firmware think it has crashed, and lose positioning.
Napsal : 21/01/2020 5:11 am
Olef
 Olef
(@olef)
Posted by: @dreadzly76
The firmware will not allow you to move below position 0 even if you do not have a problem.
Napsal : 21/01/2020 6:58 am
