Wire broken on print head and filament sensor not working Need Help
Rupa
 Rupa
(@rupa)
I had done a print and it failed and I made the mistake of printing overnight. (never doing again) and I wake up to filament shoved all up the extruder assembly. I preheat the printer and try to remove as much as I can without disassembling the printer head. Apparently the filament had wrapped around some of the wires and when I was trying to remove the filament it ripped the cable. I am not sure what I should do right now. There is an image attached. The filament sensor is also not working but it has been like that for a while. Here are some pictures. Need Help
Napsal : 05/06/2020 1:39 am
Olef
 Olef
(@olef)
RE: Wire broken on print head and filament sensor not working Need Help
You need to purchase a new hotend thermistor and fit it. Make sure to only use the correct Prusa part.
Napsal : 05/06/2020 6:45 am
Rupa
 Rupa
(@rupa)
Where do I buy it?
Napsal : 05/06/2020 7:30 pm
@rupa-s
Semitec GT104 (100kohms at 25degrees C.):
https://www.3djake.at/e3d/prusa-thermistor
https://shop.prusa3d.com/de/mk3mk3s/205-hotend-thermistor-e3d.html
https://www.igo3d.com/original-prusa-hotend-thermistor-e3d
https://de.aliexpress.com/w/wholesale-prusa%20i3%20thermistor.html
https://www.printedsolid.com/products/prusa-mk2-mk3-thermistor-cartridge?variant=12645439144021
a.s.o...
Napsal : 05/06/2020 8:05 pm
