Which Retract Value is taken?
Nomad965
(@nomad965)
Need some clarification, I noticed that the Slicer has two areas where one can input the retraction settings one is under printer settings / extruder and the other is in Filament settings / filament overides.
The way I understand this is the default is under printer settings / extruder and the filament overides is the ones based on filaments defined by the user which will overide the ones set in printer settings, is this correct ?
Thank you
Este debate ha sido modificado el hace 6 years por Nomad965
Prusa i3 MK2s MK2.5s Mk3 Mk3s BearPrusa Zaribo 320 - Kit Build - Rc Driver - Tweak freak...
“I know nothing about surpassing others. I only know how to outdo myself.” -Bushido-
Respondido : 27/05/2020 3:03 pm
RE: Which Retract Value is taken?
That is correct. The filament ones if set over ride the defaults.
Respondido : 27/05/2020 5:51 pm
1 les gusta
Nomad965
(@nomad965)
@neophyl
Thank you for the clarification.
Respondido : 28/05/2020 3:09 am
