Ways to damage a heatbreak... please help
Kopplog
(@kopplog)
Hello,
I haven't achieved to get any help so far - I have problems with my 3ED V6 Hotend.
I reassembled it 6 full times in a row of pure frustration. First I had multiple leakages, now I added some more force screwing things together but other problems occurred (old thread here)
I always put the parts - nozzle, heatbreak, etc... on my hotplate to burn things off.
Maybe I ruined the heatbreak?
Somebody's helping??
Posted : 25/11/2021 7:07 pm
Kopplog
(@kopplog)
RE: Ways to damage a heatbreak... please help
So, I can't ruin the heatbreak by heating on the heat plate, very well.
Posted : 26/11/2021 12:09 pm
Xanthe
(@xanthe)
It's certainly possible to easily damage the mating surface on the top of the nozzle, and that will ensure leaks!
Putting it on a hotplate... what do you mean by a hotplate?
Heating  most plastics above their decomposition temperature (about 280°C for PL, to about 450°C for PC) for an extended time will usually result in carbon rich deposits.  Removing these using just heat and oxygen from the air typically needs >>600°c for many hours.  If you have deposits on the mating surface of the heatbreak, then that could prevent an adequate seal.
Posted : 26/11/2021 12:10 pm
Kopplog
(@kopplog)
I usually break the hotend to pieces and put the oozed parts on the hot plate, while I sucking up the fume.
Posted : 26/11/2021 12:17 pm
Kopplog
(@kopplog)
I looked up:
A hotplate like this shouldn't have over 400 C max.... and I haven't had heatened up to the max.
Posted : 26/11/2021 12:32 pm
Kopplog
(@kopplog)
Okay,
my Hotend seems to work again. So:
I'll give a green tllight to my approach. Highly recommended, after cleaning cloaked nozzles etc are a piece of cake cleaning...
Bye
Posted : 26/11/2021 4:41 pm
Kopplog
(@kopplog)
Again, I run out of time for editing my faulty language...
Okay, hope you got the idea!
PS... timed out editing sucks too hard!!!
Posted : 26/11/2021 4:51 pm
Dan Rogers
(@dan-rogers)
Yikes. Good luck with that.
I'd be worried about heat cracks and the fire risk of using that heat plate like that.  Happy printing.
Posted : 27/11/2021 10:22 am
