USB connection using prusalink installed on Raspberry Pi 4B
Albert Pracz
(@albert-pracz)
I've a problem with connecting the original Prusa MK3S+ to Raspberry Pi 4B using a USB cable. I've already updated printer software to 3.13.3 and prusalink is a 0.7.2 version downloader from GitHub and installed with a genuine RPi flasher onto a microSD card. I see that prusalink is connected to my router and I see the 192.168.0.106 (typically) on the DHCP allocation table. I'm not able to connect to this IP address to get access to the web configurator. My printer when connected to USB(tried all of the RPi ports) doesn't show any IP address on the bottom line of the screen and I don't see "Prusalink starting" on screen either. Is there any solution or maybe some kind of troubleshooting that I can proceed with? Any ideas?
Napsal : 26/03/2024 1:35 pm
Albert Pracz
(@albert-pracz)
RE: USB connection using prusalink installed on Raspberry Pi 4B
I've reflashed RPi 3-4 times and after last reflash it just started working. So this case may be considered as closed. Maybe it was some kind of transitory condition?
Napsal : 31/03/2024 2:53 pm
