Top Layer looking a little off
MetaMarkTea
(@metamarktea)
Not quite sure what happened here, most of the layers looked great until it got to the top layer.  Then everything seems to look a bit blobby?
Is my Live Adjust Z too high or too low? or does that not really matter for anything but the first layer?
Thanks for any advice!
Top Layer
Opublikowany : 04/01/2023 5:30 pm
Hello
(@hello)
RE: Top Layer looking a little off
Please do first layer cal and post photo of the square please
Opublikowany : 04/01/2023 7:18 pm
Hello
(@hello)
Oh and what printer are you using
Opublikowany : 04/01/2023 7:19 pm
MetaMarkTea
(@metamarktea)
Its a Prusa M3KS+ Self-Assembled Kit
Opublikowany : 04/01/2023 7:21 pm
Hello
(@hello)
Ok can you post photo of bottom of print please aswell
Opublikowany : 04/01/2023 7:23 pm
Hello
(@hello)
And I am guessing printer is pretty new
Opublikowany : 04/01/2023 7:28 pm
MetaMarkTea
(@metamarktea)
Yes, this was the first large print.  The smaller test ones were a little better.
Opublikowany : 04/01/2023 7:33 pm
Hello
(@hello)
Lower the height a bit on first layer cal
Opublikowany : 04/01/2023 7:40 pm
Hello
(@hello)
Then try print 20 mm by 20 mm box on draft setting
Opublikowany : 04/01/2023 7:42 pm
MetaMarkTea
(@metamarktea)
Lowered from -1.385 to -1.418
Opublikowany : 04/01/2023 7:43 pm
Hello
(@hello)
Try lower just a little bit more
Opublikowany : 04/01/2023 7:57 pm
Hello
(@hello)
Opublikowany : 04/01/2023 8:01 pm
MetaMarkTea
(@metamarktea)
Top Layer at -1.42:
First Layer at -1.42:
Opublikowany : 04/01/2023 8:14 pm
Hello
(@hello)
that dosent look to bad
Opublikowany : 04/01/2023 9:20 pm
Hello
(@hello)
maybe try print the big print again
Opublikowany : 04/01/2023 9:21 pm
I disagree, that first layer is nowhere near squished enough.  You are aiming for an unbroken first layer
Opublikowany : 04/01/2023 9:22 pm
Hello
(@hello)
yeah but its ok to see if the big print still has the horible finish to it
Opublikowany : 04/01/2023 9:24 pm
Again, I disagree. With a first layer like that I’d be worried about part adhesion and it finishing the large print without it detaching.
There is zero point doing anything large or small until you can get a repeatable, reliable first layer. That can be done by printing single layer 75mm square patches in a quick and timely manner.
While I agree that the first pictured models top layer shouldn’t be a direct relation to the first layer calibration as it’s really really bad you have to sort out more basic problems like a proper first layer before you can go looking to debug other issues. You sort out one problem at a time.
Opublikowany : 04/01/2023 9:35 pm
1 ludzie polubili
MetaMarkTea
(@metamarktea)
Oh wow, thats a lot more squished for sure!  I can try going more for first layer.
Opublikowany : 04/01/2023 10:31 pm
