Switching between Firmwares ?
I'm not sure on this, as I'm haven't found a clear statement, is it possible to switch FW back and forth, independent of the version or is there a procedure to follow ? I'm having bad issues with 3.4 on my MK3 and would like to go back to 3.3.1if possible, to test is issues persist. Thanks for the help
Opublikowany : 23/09/2018 6:59 pm
Re: Switching between Firmwares ?
Yes, you can. 😉
I did it on Saturday because of problems with the actual FW.
Went back to (i think) 3.3.1.
Now it works as good as before.
nec aspera terrent
Opublikowany : 24/09/2018 11:23 am
Topic starter
answered:
Great Thanks 😀
Opublikowany : 24/09/2018 1:31 pm
