spares like thermistance, heater cartridge,
May be I made a mistake, I repost ....
He,
I would like to have available at home at least one of each main 'consumable" replacement parts, like thermistance ,Heater Cartridge , Throat Heat Break, Heatsink, Heater Block .... unfortunately, I did not found any info or spec on the site.
a/ The only one I found on the e-shop is the specific PTFE for MK3/MK2S ..... but not indicated as being usable on the MK3S ? for this last, I found "How to trim PTFE tube" on the site. tks.
b/ should it be interresting to install an E3D High Precision Heater Cartridge 30W (*) which is attached to a separate connector for quick release instead of the one provided with the kit ? This should be helpfull in case of failure due to any futur mishandling as I frequently change my noozle size.
(*) https://e3d-online.com/high-precision-heater-cartridges
c/ no Heater Cartridge spec found : Is its 30W power enough ? which best one to purchase ?
d/ what about the replacement part for the Thermistance ? no spec found : which best one to purchase ?
e/ how to get one or two additional PRUSA custom heatbreak developed together with E3D ?
f/ where to find the best one ( and which one) Heatsink and Heater Block fully compatible with the MK3S ?
nb : I already have a few E3D noozles purchased for use on my current printer ( unfortunately not -yet- a PRUSA )
Many Tks.
Philippe
Re: spares like thermistance, heater cartridge,
They are all there, make sure you log into your account on shop.prusa3d.com first though.
He Stephen,
tks for your fast answer.
logged as for this forum but do not see any of them .
Philippe
Check with support. They may need to activate the store for your account.
will do, tks.
Done by Marcin. I have now acces to all required spares.
Tks to both of you.
Philippe
