spares like thermistance, heater cartridge,
phmalcontacts@gmail.com
(@phmalcontactsgmail-com)
May be I made a mistake, I repost ....
He,
I would like to have available at home at least one of each main 'consumable" replacement parts, like thermistance ,Heater Cartridge , Throat Heat Break, Heatsink, Heater Block .... unfortunately, I did not found any info or spec on the site.
a/ The only one I found on the e-shop is the specific PTFE for MK3/MK2S ..... but not indicated as being usable on the MK3S ? for this last, I found "How to trim PTFE tube" on the site. tks.
b/ should it be interresting to install an E3D High Precision Heater Cartridge 30W (*) which is attached to a separate connector for quick release instead of the one provided with the kit ? This should be helpfull in case of failure due to any futur mishandling as I frequently change my noozle size.
(*) https://e3d-online.com/high-precision-heater-cartridges
c/ no Heater Cartridge spec found : Is its 30W power enough ? which best one to purchase ?
d/ what about the replacement part for the Thermistance ? no spec found : which best one to purchase ?
e/ how to get one or two additional PRUSA custom heatbreak developed together with E3D ?
f/ where to find the best one ( and which one) Heatsink and Heater Block fully compatible with the MK3S ?
nb : I already have a few E3D noozles purchased for use on my current printer ( unfortunately not -yet- a PRUSA )
Many Tks.
Philippe
Posted : 03/03/2019 11:39 am
Steve_AU
(@steve_au)
Re: spares like thermistance, heater cartridge,
They are all there, make sure you log into your account on shop.prusa3d.com first though.
Posted : 03/03/2019 11:45 am
He Stephen,
tks for your fast answer.
logged as for this forum but do not see any of them .
Philippe
Posted : 03/03/2019 12:21 pm
Martin_au
(@martin_au)
Check with support. They may need to activate the store for your account.
Posted : 03/03/2019 1:45 pm
will do, tks.
Posted : 03/03/2019 7:19 pm
Done by Marcin. I have now acces to all required spares.
Tks to both of you.
Philippe
Posted : 05/03/2019 7:06 am
