Slic3r PE and PrusaControl "top" layer problem
Ken
 Ken
(@ken-4)
I'm slicing a simple model that has a platform and three rails. When Slic3r PE and PrusaControl come to the top of the platform they both fill in the entire surface before continuing on to create the thin rails. Simplify3D and Cura take a more "conservative" approach. The difference in the printed result is significant. Slic3r PE (and I assume PrusaControl) display an artifact at that level while the prints produced with Simplify3D and Cura do not. I've seen this same difference when printing a simple box. The box pictures are from months ago so this has been an issue with Slic3r for a long time. (having trouble attaching more than 3 files so I'll post the others in replies to my post)
Ken
Thanks,
Ken
Opublikowany : 20/06/2018 5:22 pm
Ken
 Ken
(@ken-4)
Re: Slic3r PE and PrusaControl "top" layer problem
here are the Simplify3D and Cura solutions
Ken
Thanks,
Ken
Opublikowany : 20/06/2018 5:23 pm
Ken
 Ken
(@ken-4)
here are the printed results (artifact - Slic3r) no artifact (Simplify3D and Cura)
Thanks,
Ken
Opublikowany : 20/06/2018 5:25 pm
Ken
 Ken
(@ken-4)
It's been a problem for a while, box on left was sliced with Cura, box on right was sliced with Slic3r - several months ago.
Thanks,
Ken
Opublikowany : 20/06/2018 5:26 pm
Erik
 Erik
(@erik-3)
I've been noticing this since I started printing back in February. I suggest you take this over to the Github page and report it as a bug. With all of the information you've provided maybe we can get a fix.
https://github.com/prusa3d/Slic3r/issues
Opublikowany : 21/06/2018 2:28 pm
Ken
 Ken
(@ken-4)
Done!
Ken
Thanks,
Ken
Opublikowany : 21/06/2018 10:37 pm
AlexD
(@alexd)
Did you work out how to fix this issue?
Opublikowany : 15/09/2018 3:20 am
