Size Calibration
dr_rafiki
(@dr_rafiki)
Size Calibration
I built two I3 MK3s at exactly the same time in March of '18. They both print fine, but one of them prints things slightly larger than the other. What should I do to get them to print identical sizes?
Publié : 05/10/2018 6:24 pm
Re: Size Calibration
Have you calibrated your extruders? The procedure describes tuning the extrusion rates in your slicer. Since you have 2 printers, that approach might be a pain since you'd have to maintain a separate profile for each printer. You might prefer to do the calibration on each printer so you can use the same generated gcode on both. Here's a good description of the approach in general, and some Prusa-specific discussion.
Publié : 05/10/2018 6:28 pm
dr_rafiki
(@dr_rafiki)
Thanks, but it is definitely not the extruder. I printed a 150mm square frame on each of them. One of them measures 149.8 x 149.6. The other one measures 150.0 x 151.5, so neither of them is square, and there is a huge difference between the two.
Publié : 07/10/2018 5:01 pm
