Shifts in Y-direction
emilm
(@emilm)
Utenti
Since quite some time I have been encountering shifts in the Y-direction when printing. But at seemingly random intervals. I have checked the belt tension on all axes multiple times. I don*t see a lot of wear on the Y belt so I didn't replace it. If anyone thinks that's necessary I'd do that too. Here is a picture of the effect:
It's the worst on the left print but even on the right one the right wall is supposed to be entirely straight which it obviously isn't.
I'm completely out of ideas! I would greatly appreciate any help!
Postato : 19/01/2025 4:25 pm
First check the Y idler is moving freely but a more likely cause is slipping of the drive pulley on the motor shaft.  Ensure the grub screws are corectly positioned and tightened.
See step 28 on: https://help.prusa3d.com/guide/2b-y-axis-assembly_165795
Cheetio,
Postato : 19/01/2025 5:20 pm
emilm
(@emilm)
Utenti
RE: Shifts in Y-direction
Now I feel stupid for not having checked this but that actually seems to have been the fix. Thanks a lot!
Cheers, Emil
Postato : 19/01/2025 7:04 pm
