Problems with first layer print
Mihail
(@mihail)
Printer (Prusa i3 MK3S+) was printing OK, but suddenly when I started to do another print (after 5 minutes, from the last print) it failed to print first layer.
I made first layer calibration but I could not succeed to manage to print well right part of the print. Seems to be always "high". May be I need to do https://help.prusa3d.com/article/bed-level-correction_2267   (bed level correction)? It is interesting why it suddenly stopped. I also clean the nozzle, with needle and brush, still the same.
Here is a link of the picture from calibration which shows the problem
Best Answer by JustMe3D:
Changing the nozzle will get you nowhere. Clean the bed with non-regreasing dish soap, hot water and scrub it with non-regreasing kitchen paper. Then get a decent live-Z installed, see https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/life-adjust-z-my-way/
Regards
Chris
This topic was modified 3 years ago 2 times by Mihail
Posted : 19/09/2022 6:54 am
Thejiral
(@thejiral)
The printed surface of your 1st layer doesn't look that great either. Almost as if it is too low there.
Have you tried repeating the selft test with subsequent recalibration?
I would also look if your PINDA is screwed tightly in place or has come loose.
Posted : 19/09/2022 9:27 am
Mihail
(@mihail)
RE: Problems with first layer print
I know that it is too low, but was a result of making right hand to be printed in a good way. Unfortunately lowering Z does not affect it. Will check PINDA.
Posted : 19/09/2022 10:50 am
Thejiral
(@thejiral)
Also rerun the self test procedure. It does include a test regarding the tilt of your axis'. I think it also includes a calibration of your z-axis, which might indeed be the culprit here.
This post was modified 3 years ago by Thejiral
Posted : 19/09/2022 11:34 am
Mihail
(@mihail)
Did not work. Will try to change the nozzle.
Posted : 19/09/2022 7:36 pm
JustMe3D
(@justme3d)
Regards
Chris
Posted : 19/09/2022 8:29 pm
Mihail
(@mihail)
Hi JustMe3D,
You are right. After good "bath" with all the treatments, quality printing is back. Thanks for all the support from all who read and responded.
I never believed that just that simple cleaning will bring the live back of "happy printing".
P.S. JustMe3D, you write that you are not pro but I think you are.
Posted : 20/09/2022 9:26 am
