RE: Problem with slicer
Can you post a link to an STL with this problem? Ideally, zip & upload your project file with your settings and the part. Without that, we're pretty much guessing.
Ah! It didn't allow me to upload STL files. I forgot all about ZIp files 😉
This is the STL file:
IoT Box Rev 2
Thanks Lars Bo Wassini
There are problems slicing with Cura as well. The extra layer is gone, but the holes along the back wall are also missing.
It is how the part is being built; some of the features are multiple parts, for example the 10bT hole has an extra "wall" in it from the surface below the hole. Basically, all of the component bits were never fused properly before moving on in the design. I think it's a bug in the union code of the CAD tool.
Also, the model isn't even manifold. So lots of things to fix back in Sketchup.
