Printer randomly stops with these weird characters on the screen
DoodadsOnDemand
(@doodadsondemand)
The below image is what randomly happens during some prints. Not sure why or where to look.
Fusion 360 -  create object and export STL
PrusaSlicer-2.2.0 import STL and slice
Printer MK3 3.81-2869 - sent to the printer via octprint 1.5.3
Octoprint 1.5.3
Any help is greatly appreciated.
Thanks,
Brian
Printer screen
Publié : 27/01/2021 2:53 am
DoodadsOnDemand
(@doodadsondemand)
RE: Printer randomly stops with these weird characters on the screen
Does anyone have any ideas? This just randomly happens during a print. I cannot isolate it to a certain print or a certain layer within a print. It sometimes happens seconds into a print or hours.
Thanks,
Brian
Publié : 02/02/2021 6:45 pm
DoodadsOnDemand
(@doodadsondemand)
Just discovered it happens with just the printer sitting idle. Anyone have any idea what could be causing this?
Publié : 10/02/2021 8:15 pm
Pétur
(@petur)
I'm having the same problem, did you figure out what was causing the issue?
Publié : 13/01/2022 10:52 am
Check the connections at both ends of the LCD cable, one end has probably vibrated loose.
Publié : 13/01/2022 12:46 pm
DoodadsOnDemand
(@doodadsondemand)
I checked LCD connections they were good but still having the issue.
Publié : 13/01/2022 3:57 pm
DoodadsOnDemand
(@doodadsondemand)
I will post an update if I ever get it figured out. Luckily I have more than one printer.
Publié : 13/01/2022 4:01 pm
OK, take this one to Prusa support: Log into your Eshop account, navigate to Help and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
Publié : 13/01/2022 4:45 pm
Pétur
(@petur)
My LCD connections are good. I found that my heatbed thermistor is losing connection resulting in MINTEMP error but I don't know if that has anything to do with the LCD getting scrambled.
Publié : 13/01/2022 8:21 pm
1 personnes ont aimé
DoodadsOnDemand
(@doodadsondemand)
I need to check that as well. Thanks
Publié : 13/01/2022 8:43 pm
DoodadsOnDemand
(@doodadsondemand)
I pulled it apart and if I wiggle the heatbed thermistor wire it results in MINTEMP ERR. Maybe that is what is causing it but I am not sure what exactly is wrong. The wire seems to be connected well at both ends.
Ce message a été modifié il y a 4 years par DoodadsOnDemand
Publié : 13/01/2022 10:17 pm
Pétur
(@petur)
Can confirm after replacing heatbed thermistor and heatbed power cables that my issue is resolved.
Publié : 22/01/2022 8:17 pm
DoodadsOnDemand
(@doodadsondemand)
I can confirm after replacing the heat bed entirely since they were out of the thermistor it is now printing again. We will see how long it goes this time. I think it has printed enough now that I can say it is fixed but I have several large print jobs to do so fingers crossed!
Publié : 26/02/2022 10:17 pm
