Printer not moving up Z since update
Hobbes
(@hobbes)
I am trying to print some masks for a nursing home.  I hooked up and tested my printer with a couple of designs.  They printed well.  I downloaded a mask design, sliced and exported, and before printing, the printer said there was a firmware update.  So, I updated the firmware and software/drivers for good measure.
Since then, I can't get anything to print.  The printer runs around the design, but never rises above the first level.  It keeps dragging the head around at the first level.  I thought it might be the new design, so I tried one of the older gcodes I had just test printed and they do the same.
I ran autohome, xyz calibration, z calibration, first layer calibration, replaced the nozzle, ran them all again.  I can't find the problem.  There is no problem with the z-axis.  It moves up and down during testing and other operations normally.
I downgraded the firmware by flashing 3.8.0 (down from 3.8.1).
None of these fix the problem.It just keeps printing without moving up Z.  I would really appreciate some help.  I'd like to print these masks for brave nursing home staff.
Thanks
Veröffentlicht : 08/04/2020 11:43 pm
Peter M
(@peter-m)
RE: Printer not moving up Z since update
Did you use the correct firmware, for your printer model?
Search forum how to reset the settings inside the printer, so you are 100% safe that the old calibration setting are gone.
And there is no reason to update the printer if everything works, is not needed.
Veröffentlicht : 09/04/2020 10:17 am
Hobbes
(@hobbes)
I have an I3 MK3 which I had some upgrades done to so it is a MK3S.  I am using the correct firmware.
I had some SERIOUS calibration problems which Prusa spent over 8 hours trying to diagnose and sending me replacement 2 replacement PINDAs for.  Prusa was unable to fix it so I had to pay a local 3d printer repair shop to reset everything.  They informed me that the problem was not a calibration issue then.  So, I am concerned that if I reset everything now, I will wind up back where I started with a printer that won't even pass calibration tests and I will have to pay them again to fix the firmware.
This is why I have not reset the printer.  I am concerned it will revert to its previous state where it fails Z-axis calibration tests.  I will do it if nothing else works, but I am not there yet.
I will remember the 'no reason to update' advice in the future, though it is not helping me now.
Thanks for your reply, but I am hoping someone has seen this problem and knows specifically what the cause is.  The print keeps printing on the first level and never rises.
Veröffentlicht : 09/04/2020 1:24 pm
when the printer is turned on, and at rest.
press and hold the knob for about 3 seconds,
does the display change to
Z:            +0.0
if so, does rotating the control knob Clockwise cause the printer to raise the extruder?
Veröffentlicht : 09/04/2020 1:37 pm
