        Print speed and ghosting/ringing
Trying to diagnose some minor to moderate ringing and ghosting on tall cylinders. Prusa help article suggests slowing down the print as one test. When I search for "speed" in Prusa Slicer I get a ton of results. Is there an overall setting to slow the print down opposed to adjusting all the little settings like perimeter speed, infill speed, etc. If the speed doesn't fix it I will investigate the belts and keep knocking off troubleshooting items till I get it figured out. I have a spare X and Y belt on hand in the event I have to replace one. Using default .15 PETG Prusa profiles for the MK3S+MMU2S. Thanks and looking forward to some suggestions from the community.
                            Opublikowany : 15/01/2022 11:02 pm
