PINDA does not trigger when i try to print, every time.
Manux
(@manux)
Hello Fellow Prusa Members.
I tried out different filaments and one clogged my extruder. After cleaning it (full disassambly) the pinda does not find the 1. Calibration point anymore.
I have the full steel spring mod for the bed so i can ajust the height. However i found that if i use the original spacer on the front left point it gives the most accureate result in finding the point. That is: printing works one time after i redo the XYZ Calibaration, Then it works one time and then it does not anymore.
Also note, this works:
- Auto Home
- Z Calibation is able to find the points.
I have a volcano hotend installed but this gave never any reasn for concern.
Of course i followed the usual trouble shooting points...
Specific questions:
- What is the height from the y Rod the the top of the bed. So i can tune my spring to that height?
- Any Firmware values i could tweak for searching for the bed in a bigger Height range ?
Note: I use stock firmware 2.9. rc1 with wolfes Volcano Mod.
I know this issue seems like it is easy to fix but i tried a lot of things.
I think the best combination would be:
- Increase the height of the "Search for bed right now for 1mm"
- Correct height from xy Rods to the top of the bed so i can get better in Rangen the the search for the bed.
Any help aprechiated 🙂
Thanks guys
Publié : 19/04/2020 9:40 am
