Paused Thermal Error
Andrew Fellows
(@andrew-fellows)
Membre
Hello All
I have been struggling with one of the MK3s I have here at work, initially we were getting Power Panic crash cycles when the bed heats, so I replaced the bed heater and bed thermistor, updated firmware and did a calibration wizard and Thermal HW calibration.
started a print and it was fine for about 2/3 of the print, it then started beeping and throwing up a "Paused, Thermal Error" message on the LCD screen.. so I stopped the print, did a PID Calibration and then getting a Thermal Runaway message.
reset the machine and started a print once again just a simple Benchy, and it would heat up, then go into yet another power panic cycle. unplugged the power panic cable and restarted a print, got to about 2/3 of the way, then again a new thermal error and layer shifting before it stopped completely.
and because I had a spare head thermistor and heater around I swapped them out as well just in case and yet I am still getting the same issues, so I am at a bit of a loss here with this one, FW and Slicer are the latest versions. no aftermarket parts or any remote control.
any help would be appreciated.
thanks
Publié : 26/09/2023 9:29 am
Gilles160
(@gilles160)
RE: Paused Thermal Error
Hi
Did you find a aolution ? I have exactly the same issue. My printer repeats "paused thermal error" every 10 or 15mn
This is very anoying...
Publié : 21/10/2023 2:02 pm
snackob
(@snackob)
I have also been getting this error now. I tried various versions of the firmware, didn't help. Did anyone solve this?!
Publié : 08/12/2023 8:14 pm
Gilles160
(@gilles160)
Yes I did
By replacing the thermal sensor
Publié : 08/12/2023 8:21 pm
