nozzle temp changes no matter which filament profile selected ..
Mike G
(@mike-g-4)
Hi All,
just got a problem after a recent firmware upgrade - have selected a Flex profile in the slicer, and once  start the printer via octoprint, i notice the nozzle/bed temperature does change after short time to 160/0 degrees - no matter which profiled i have selected.- Has someone already come across this problem
rgds<Mike
Opublikowany : 13/03/2024 7:29 pm
Mike G
(@mike-g-4)
well, finally after searching around an mas nobody was obviously havend had this problem i Found the solution to my problem.
Problem:
There was obviously 3MF file which contained some strange settings, which had been imported into the slicer, overriding the default.
How did I find it..
I took the g-code into notepad++ And searched for the code M109 s160, Which I found in the initializing code for the printer.
Solution:
I took the configuration Wizard for the slicer and went through all important steps to regenerate the machine, dependent default parameters for the printer - now, everything is back to normal
lessons learned:
never confirm change of settings when you import 3MF file into the slicer
This post was modified 2 years temu 2 times by Mike G
Opublikowany : 15/03/2024 4:16 am
