nozzle obstructed before calibration
I would like to heat up the nozzle to melt out the obstruction, however, the screen menu forces the calibration.
What should I do? should I remove an clean the nozzle or try to heat up the nozzle?
RE: nozzle obstructed before calibration
You should be able to heat the nozzle without moving the printhead by going to the pre-heat item from the LCD menu and select the type of filament you have loaded.
Mk3S+,SL1S
Or you can go to settings/temperature/nozzle.
OK, but whenever I switch on the prusa the screen reduces the option to calibration... how do I enter into the nozzle heat/temperature menu. Thank you.
tried many combinations of buttons but to no avail...
