nozzle obstructed before calibration
carlesls
(@carlesls)
I would like to heat up the nozzle to melt out the obstruction, however, the screen menu forces the calibration.
What should I do? should I remove an clean the nozzle or try to heat up the nozzle?
Veröffentlicht : 14/02/2022 11:21 pm
sylviatrilling
(@sylviatrilling)
RE: nozzle obstructed before calibration
You should be able to heat the nozzle without moving the printhead by going to the pre-heat item from the LCD menu and select the type of filament you have loaded.
Mk3S+,SL1S
Veröffentlicht : 14/02/2022 11:54 pm
Or you can go to settings/temperature/nozzle.
Veröffentlicht : 15/02/2022 1:53 am
carlesls
(@carlesls)
Posted by: @sylviatrilling
OK, but whenever I switch on the prusa the screen reduces the option to calibration... how do I enter into the nozzle heat/temperature menu. Thank you.
Veröffentlicht : 15/02/2022 1:56 am
carlesls
(@carlesls)
Posted by: @fuchsr
tried many combinations of buttons but to no avail...
Veröffentlicht : 15/02/2022 2:33 am
