Need sanity check on first layer calibration
Attached is my first successful print from a MK3S+ &MMU2S. It was printed with a 0.4 mm nozzle, 0.2 mm layer height (Quality mode). As you can probably figure out, it's a control panel that's 0.8 mm thick (There's a PCB behind it that the components are soldered to). My question is whether I should squish the first layer down a little more? It seems like I'm seeing too much space between the strands of filament here.
Thoughts?
Thanks
Bill Lugg
Bill Lugg
Veröffentlicht : 23/07/2021 10:33 pm
I think you may need to go a bit lower, looks like you need more squish.
Regards
Swiss_Cheese
The Filament Whisperer
Veröffentlicht : 23/07/2021 10:37 pm
