MK3S - X Reset Button - Equivalent Software Command ?
HeyRob
(@heyrob)
Hello,
    I am looking for a command that resets the MK3S, that I can execute remotely through OctoPrint, that has the same functionality as the physical reset button under control knob. I don't want to factory reset, or resume a print... I want it to simply 'soft' reset. I see different D and M codes that -might- do that, such as D0 B (reset bootloader)... just not clear on whether these commands flush calibration or config data.
Any help would be greatly appreciated, thank you all!
Opublikowany : 31/03/2020 1:21 am
RE: MK3S - X Reset Button - Equivalent Software Command ?
HeyRob,
What happens if you disconnect and re connect using Octoprint?
I thought that forced a reset...
Opublikowany : 31/03/2020 9:27 pm
HeyRob
(@heyrob)
Hi joantabb,
  I have not tried that... just seems sort of excessive, wouldn't you agree? I just figured it would have been an easier command that can be issued to the printer to cause it to soft-reset... since Marlin FW seems to offer multiple 'types' of reset options, and even Prusa's own-specific g-gcodes indicate a method of 'resetting' the printer... D0, D1, M502... there just isn't enough documentation on what exactly D0 and D1 do to the printer.
Opublikowany : 01/04/2020 12:11 pm
CPAC_TD_F
(@cpac_td_f)
Came here looking for the same thing. Is there a g-code or m-code equivalent to pressing the reset button on the front panel?
Opublikowany : 19/04/2020 6:06 pm
HeyRob
(@heyrob)
Hello bbel,
I ended up contacting Prusa over this question, and they confirmed that a D0 command would indeed reset the printer. Unfortunately, during my testing, this is not the behavior I observed. (No change in behavior observed). If you here if anything, please let us know!
Opublikowany : 19/04/2020 6:48 pm
I don't know any way to trigger a x-reset by command. I solved it via the Raspberry pi over gpio (connected 2 lines on the lcd ribbon cables - gnd/reset). Reset over USB also workes.
Opublikowany : 19/04/2020 9:54 pm
