MINTEMP Error & Heater/Thermistor Error on Bed Selftest
juli0r
(@juli0r)
Hi!
I have my MK3S for quite a while, but never got around to repairing it after I got an extruder blob and removed it. So it stood around unused for over a year.
Now I got some time again and tried, but despite already having exchanged both thermistors (hotend and heatbed) it still says there is a Heater / Thermistor Error and after a restart it shows the "MINTEMP" error (not mintemp bed).
The display consistently shows 0/0° ~21/0° as if it doesn't have any temp information at all except for the environment temp. At least I assume the second row first value is the env. temp.
I am a bit at a loss about what to do. As I said - I already replaced both thermistors. Any help/suggestions?
Questa discussione è stata modificata 3 years fa da juli0r
Postato : 17/03/2023 8:48 pm
RE: MINTEMP Error & Heater/Thermistor Error on Bed Selftest
if you are a handy person, you could consider fabricating a test resistor, that you could connect to one of the thermistor inputs.
If you use a 100 K Ohm resistor, the display should show approximately 25C.
regards Joan,
Postato : 17/03/2023 9:57 pm
juli0r
(@juli0r)
Thanks for the answer.
Not really a handy person, but I could give it a try.
What would that tell me though? I guess if it shows a temperature with resistance built in the board works correctly and the failure happens somewhere else and if not it's probably the board that's the problem. Is that right?
Postato : 18/03/2023 5:14 pm
That is correct.
Postato : 18/03/2023 6:04 pm
