Mesh bed calibration error only before a print
michele.p5
(@michele-p5)
I'have bought a I3MK3 pre-assembled, i've printed fine for some weeks. Suddenly there are continuos errors during the mesh bed calibration before a print. I've made a factory reset, uninstalled and reinstalled drivers and software, updated the firmware end made all the calibrations many times. During the calibrations it's all fine, but at the start of the printing process, 8 times on 10 there are errors during the mesh bed calibration and the printer start to calibrate the Z again and again resolving the issue only sometime. The error is not always on the same calibration point. I' ve tried to vary the PINDA height whitout luck. What can I do? Thanks in advice.
Napsal : 26/03/2019 7:41 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
Re: Mesh bed calibration error only before a print
contact prusa online chat system 24/7 support
log into your account on one of the prusa store pages and in the bottom right corner you will see the Chat system box click in it enter your Invoice number for you Prusa and start the chat system; they do an excellent job and will take good care of you. They go the extra mile for folks with assembled printers
Napsal : 27/03/2019 5:40 am
michele.p5
(@michele-p5)
Thanks, i'll give it a try. 😀
Napsal : 27/03/2019 1:27 pm
Kraken
(@kraken)
Try download and print this G-code.
https://www.dropbox.com/s/f5ym576a9qehh6a/TEST_360.gcode?dl=1
It's modified prusa logo from original SD card.
Napsal : 27/03/2019 8:56 pm
Lukas
(@lukas-3)
I have solution, not the best but it works. Just turn off bed before mesh bed leveling. Example for PLA.
M104 S215 ; set extruder temp
M140 S60 ; set bed temp
M190 S60 ; wait for bed temp
M109 S215 ; wait for extruder temp
M140 S0 ; set bed temp
G80 ; mesh bed leveling
Napsal : 28/03/2019 6:35 am
michele.p5
(@michele-p5)
Thank for the replies, yesterday I've contacted the support on live chat and the operator can't help me. He told me that they will contact me by email.
To Kraken: the issue is always present.
Sorry Writeon, but i'm not an expert...
the G-code instructions have to be positioned on the start of the code? I will open a g-code file and start to study...
Thanks a lot!
Napsal : 28/03/2019 5:36 pm
Lukas
(@lukas-3)
Yes it's on the start of the G code. Just add this M140 S0 ; set bed temp between G28 W ; home all without mesh bed level and G80 ; mesh bed leveling .
M140 S0 ; set bed temp - add this line
Napsal : 29/03/2019 7:45 am
michele.p5
(@michele-p5)
Thanks for the time and the reply!
I've tried on 5 prints sent by CURA 4 and it works flawless!!!!
Thanks a lot!!!!
Is there some odd explanation? only for curiosity....
Napsal : 29/03/2019 1:51 pm
michele.p5
(@michele-p5)
Update: the support contacted me by mail and told me that the PINDA probe is faulty. They will send me a new one.
Napsal : 29/03/2019 5:33 pm
Lukas
(@lukas-3)
Can you inform us, if the new P.I.N.D.A. solve this problem?
Thank you very much. Happy printing 😀
Napsal : 01/04/2019 7:38 pm
michele.p5
(@michele-p5)
Hi!
Finally I've bought a new P.I.N.D.A. probe, installed it and solved, now I'm printing flawlessy....
So was the probe...
Happy printing 😀
Napsal : 13/04/2019 6:33 pm
