Initial Calibration fail after upgrading firmware to 3.9.1
damian.shores
(@damian-shores)
I have and MK3 and recently upgraded the firmware to version 3.9.1. When it reaches the x-Axis calibration is fails. I converted back to the original firmware and everything passes just fine. Any thoughts??
Napsal : 07/11/2020 9:48 pm
RE: Initial Calibration fail after upgrading firmware to 3.9.1
Posted by: @damian-shores
The first thing I can think of is: Did you install the MK3 firmware (not MK3S)?
It might also help if you change the belt tension a bit. I haven't checked it, but I think that the stepper motor current settings (stallguard sensitivity) have been changed in 3.9.1.
Napsal : 07/11/2020 10:33 pm
KOBALT3D
(@kobalt3d)
I think this has something to do with "More precise Belt test" improvement.
I have same issue with Selftest. Belt test reports X-axis error too. But when I downgraded to v3.8.1 Selftest is completed without any error.
I think it's a bug.
Napsal : 09/11/2020 6:04 pm
Or too much friction on X or Y ...
Did you lubricate the bearings before installation?
Are the X-Axis extruder cases screws near the bearing too tight?
Are the Y-Axis U-bolt nuts too tight?
Napsal : 09/11/2020 8:04 pm
