Impossible to compile and upload MK3 firmware correctly
Jerem
(@jerem)
Hello Guys,
I am a proud owner of a Prusa MK3 (I just uprgade to S version by the way) .
The MK3 works so well that I have decided to upgrade the electronic of my CR-10 S4 with an einsy Rambo and direct bondtech extruder.
So I bought all the require components and start to install it but I have an issue when I try to compile and upload the firmware on the board.
I can upload it but everytime the lcd screen show garbage characters and I can't connect octoprint to the printer
I don't understand what is wrong because I followed the instruction from the firmware Github, try different Arduino IDE, on different PC.
The problem doesn't come from the hardware, because when I flash the official ".hex" from Prusa everything is fine.
It seems to come from Arduino IDE. Is it possible to compile with another software?
I spent so many hours on the topic... so any help is welcome.
Thanks for your support !
Jérémy
Napsal : 19/05/2019 10:50 am
J Michael Pinc
(@j-michael-pinc)
RE: Impossible to compile and upload MK3 firmware correctly
Ditto, btw.
Napsal : 20/05/2019 8:08 am
Vojtěch
(@vojtech)
I have no issues compiling the code from git and flashing to my Mk3. Last time I've done that was yesterday. But then I'm compiling on Linux.
Napsal : 20/05/2019 10:17 am
teookie
(@teookie)
Did you do this?
In file "Firmware/config.h" set LANG_MODE to 0.
Napsal : 20/05/2019 1:46 pm
Jerem
(@jerem)
Posted by: trent.t
Did you do this?
😱 That was  the only thing I didn't try ... Now I can understand what is displayed on the screen ^^. Thanks a lot !!
I don't know why I didn't do this before.
Napsal : 20/05/2019 7:26 pm
attic_layout
(@attic_layout)
Q:I built firmware using Arduino and printer now speaks Klingon (nonsense characters and symbols are displayed @^#$&*°;~ÿ)
A:Step 2.c was omitted.
Luckily they anticipated that and added it to the FAQ as well...
Napsal : 21/05/2019 3:36 pm
Jerem
(@jerem)
Posted by: donjohnson
My bad, I didn't scrowl down until the FAQ... I was looking for the answer on others forums  😩
By the way, I am not a Star Trek fan 😉
Napsal : 21/05/2019 5:28 pm
